M8S+ openelec help please
Originally posted by lakesr View Postwhen u say apply remote patch do u mean after in installs do toothpick method again and install the remote zip? then after reboot everything should be good?
You can reboot many times - there should be no difference at all. If is - describe it here.
But if i install
http://amlinux.ru/image/6.95.1/OpenE...S-6.95.1.1.zip
then the remote file you sent it works great but then wifi dosent workWhich makes no since since really i think its an regular M8S build not + The box does seem to be runing a little warm though
Crazyness Please help lol
Originally posted by lakesr View PostJust guessing here was your plan for me to take the remote file out of the openelec that was working which I did and copy it right back into the directory of one that is not working but everything else is? If so I'm trying that now
well after hrs and hrs of trying i finally installed just a M8s Openelec and its worked great but now only problem is if i unplug it and plug back in it wont turn back on, funny thing is tho if i inset an sd card it will wake up the box to turn on so weird anyone ever had this problem?and trick to work around powering up issue?
There are currently 1906 users online. 3 members and 1903 guests.
