K1 Plus DVB-S2/T2 Firmware question.
    acemaxtec thank you for all your support on this box. I just recieved a box from Geekbuying and the box shows firmware of 20160430.111941.V1031P3 - Is this your box?
    I only find Firmware dated 20160421 on your site.
    kind regards
    cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
    http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
    Seeing that acemaxtec do not answer questions, could anyone else give me more info?
    kind regards
      Acemax & Eny Technologies use the slap together, ship & forget tv box method.
      In the past they were selling previous generation Rockchip RK3188 devices with fake 2GB RAM and using firmware tricks.
      As soon as you installed other custom firmware your RAM turned into 1GB(the real value).
      With their S805 tv boxes re-sellers that bought several devices from them soon run into trouble.
      When they wanted to install the same firmware on a different box it didn't work.
      After opening the exact same tv box models the insides all had different wifi, ethernet and other chips.
      So they were stuck with the firmware the boxes came with, with no way to fix the broken software.
      Every time a new chipset comes out they drop the old one like a hot potato even a week or 2 after release.
      Just look what happened with the new MXQ Pro+ S905 tv box they dropped support for.
      They just told their re-sellers like Gearbest the device is now discontinued and will receive no firmware updates after several people complained.
      On their website they also mention they lock the firmware so competitors can't use it which is very worrisome as you will then easily brick your device if flashing other firmware with no way to repair it.
      Read the part - 'Do not waste your money on cheap clone boxes'
      http://www.acemax.net.cn/downloading...center-14.html
      Warning
      http://freaktab.com/forum/tv-player-...-eny-or-acemax
      They also use several fake identities on freaktab which is not allowed for advertisers.
      Lots of the previous warnings of them were deleted when freaktab upgraded their forum software about a year ago.
      You won't get firmware updates.
      Or exactly the same firmware as previously but with the date edited to a newer date.
      Companies like Zidoo or Ugoos really spoil people with firmware updates while other companies have a completely different way of doing business with their customers.
        Warning
        Thank you for the extensive information, mo123 . I only bought the box to get an idea of what the DVB quality is like, which I must say is pretty good using DVB-T2. Pity acemaxtec and other K1 manufacturers dropped the support on this box as it runs actually quite nice!
        I still need to figure out how the UNROOT this device, as my cable supplier does not support rooted devices...
        kind regards
          LOL ... if you are root you can do anything, including unroot. But then: what if you want root back? Perhaps save a TWRP backup. Remove root is delete su binary and app that manages root. Now, when you do so I do not claim you are in a better situation... so, unroot at your own risk
            yes, it is our box, and you can keep on looking on our website to have new software ....
              @ mo123, first, thanks for your support on the box.
              but why did you alwasy say bad words on we acemax.
              1. did you buy we acemax products? and have you tested we acemax products..... if you did not buy from we acemax aliexpress store, we can not guarantee the box is genuine or not.
              2. acemax and ENY are 2 companies....we are different. (enev though sometimes the boxes we sell the same cabinet, we can not guarantee that theirs is the same as ours).
              3. RK3188, long story, we did not sell many(retails), we just sell to our partners(who asked to buy )....have u tested our boxes rk3188, if not, PLS DO NOT TELL THE OLD STORY AGAIN and AGAIN, and it is the not the first time that you mentioned this on this website. THANKS.
              we respect you on your hardwork...THANKS
                Thank you very much for coming back to me.
                A couple of things I would like to mention on this box:
                • It is the only 5.1.1 box working with the South African Cable company (DSTV) online streaming. (Supersport app still does not work...)
                • The DTV app catches all the DVB-T2 channels in my area.
                • To UNROOT the box was actually quite easy - Steps to follow.
                • KODI kept crashing. I uninstalled the release on the box and installed from playstore and it works like a charm.
                • Your website does not list the latest firmware, my box came with " 20160430.111941.V1031P3" and you only have the one from 20160421 on your site.
                Other than that, I was most surprised to find such a great box! I hope acemaxtec you guys keep up the firmware on this K1 Plus. It is very stable!
                To Unroot:
                1. Install "Terminal Emulator" from the Google Play Store.
                2. Make sure your device is rooted.
                3. Run the "Terminal Emulator" and enable root by typing "su" on the command prompt.
                4. mount /system as RW with this command: "mount -o remount,rw /system".
                5. Go to the app directory: "cd /system/app/"
                6. Move the Superuser directory to the /system directory: "mv Superuser .."
                7. reboot.
                To enable root: Just move Superuser back to /system/app/
                This enabled me to run all my apps without root enabled...
                kind regards
                  @ cyber7 thanks, and uploaded the latest 20160430 to the mega.. thanks for supports on our products
                    Thank you acemaxtec
                    That's great! I have some ideas for you. Do you chat on Skype?
                    kind regards
                      yes, you can add on skype
                        Invite sent
                        kind regards
                          Hello, I have bought some ki plus receiver and they have LMY47V 20160606 test-keys firmware, but this firmware is not in acemax home page.
                          The ki plus reciver is good, i only find some defect:
                          1)The support not exist. I have tried by mail, by skype, by aliexpres. If they can not help you, then they do not answer.
                          2) The has not bluetooth built-in. When i ask in aliexpress if it support external bluetooth dongle, the seller said YES to me. Now, i have probe differents bluetooth dongle and ki plus receiver not detect them.
                          i have ask about one bluetooth compatible but i have not received answer.
                          I hope acemax update the ki plus firmware with bluettoh option and show bluetooth dongle compatible list.
                          3) I think the receiver has temperature level high, If you use some usb device and you touch connector when plug off it is very very hot. I think the solution is one fan inside.
                          The rest, the receiver work good with s2 and t2 signal, kodi 16.1, etc...
                            Default KI_PLUS_DTV-ota-20161107.195841.V1031P3.zip
                            Original factory firmware.
                            PowerVU
                            Updated link: https://yadi.sk/d/abmq0HP_yGVH5
                            Detail unzip the zip and put only these 3 files below in the pen drive or SD card for installation:
                            factory_update_param.aml
                            recovery.img
                            Note: Fat32 format.
                            To update preserving apk data and settings.
                            Follow the steps mentioned here by editing the file: factory_update_param.aml
                            After downloading the zip file open it and find the file: factory_update_param.aml You have to edit it with text editor Notepad +++
                            Model of the same:
                            -wipe_data -
                            -wipe_cache -
                            -wipe_media -
                            -update_package = / sdcard / KI_PLUS_DTVota20161025.104046.V1031P3.zip
                            Remove the two lines by looking like this:
                            -wipe_cache -
                            -update_package = / sdcard / KI_PLUS_DTV-ota-20161025.104046.V1031P3.zip
                            Save and copy by replacing the original to the sd card or pen driver, all your data and settings will be saved. After the installation restarts it to return the original settings.
                            More details: http://4pda.ru/forum/index.php?showtopic=730111&st=3680
                              Is it a firmware for k1 plus with dvb S2/T2?
