Looking for better Mouse and Keyboard setup for MK808b
    I'm running Finless ROM 2.1 for the MK808b.
    I have tested a Bluetooth Microsoft mouse 5000 and the FAVI keyboard mouse combo.
    So issues that i currently have
    1. Bluetooth doesn't connect when MK808 started. I have to reestablish a connection on every start up.
    2. Both my Bluetooth and the Favi remote don't work unless they are in line of sight.
    I need a good combo keyboard/ mouse that will go through walls.
    Anyone using the K400 through walls and can make a recommendation.
    Just use Logitech K 700
    I use a Logitech K700 thats far out the best!!
      I use a ligitech k400 and works good from 20' away and in another room but did have trouble in another room when I got 25 feet away. also use a logitech m185 mous with the same experience, so it should be good however a wall will hinder the range
        I ordered the K400 and was still haveing issues. I then removed the logitech dongle and found it was getting heat from the unit. I used a USB extender to move the dongle away from the MK808 and its working perfect. Thanks for the advice on the keyboard.
        Any know why my bluetooth wont stay conected? I'm starting to like this mk808 more and more.
