Annoying MXQ Nexbox problem
I have bought a couple of MXQ NEXBOX boxes from Gearbest and they both have a annoying problem of when I press the power button on the remote to put them to sleep they won't wake up after a hour or so? If I Peres the power button after say 10 minutes they wake up fine. Anybody know what's going on or a fix? I have looked through the android settings but can't see anything to change.Tags: None
Originally posted by Raptorman View PostI have bought a couple of MXQ NEXBOX boxes from Gearbest and they both have a annoying problem of when I press the power button on the remote to put them to sleep they won't wake up after a hour or so? If I Peres the power button after say 10 minutes they wake up fine. Anybody know what's going on or a fix? I have looked through the android settings but can't see anything to change.
So you just have to live with the problems.
You won't get any firmware update from Nexbox to fix it.
Is it not possible to flash the firmware with that of a similar box??
There are currently 2471 users online. 0 members and 2471 guests.
