Bypassing PIE Checks on S95?
Got my S95 yesterday and am busy moving apps/data to it from my old Minix Neo X5. At least one app <https://play.google.com/store/apps/details?id=org.onaips.vnc&hl=en> seems to have an issue with, I think, Android 5.x on this machine (the Neo was only 4.4.2). It launches an executable and I can see, when trying to launch it manually, that there is an error regarding PIE (Position Independent Code). I see references to this issue in a few places like here <http://www.ibtimes.co.uk/bypass-pie-security-check-android-l-fix-apps-breakage-issue-1454624> and am wondering if anyone has tried flashing the bypass-pie.zip file mentioned there? If so, how do you flash it without a custom recovery? Or is there some other way to disable this check? Thanks for any help you can give.Tags: None
There are currently 4148 users online. 0 members and 4148 guests.
