How To Completely Wipe and Start Fresh?
In settings/more settings/backup and reset there is a function to reset to factory and user data wipe.
For me personally, the best way is to flash a firmware using a PC, The USB Burning Tool and a Male-to- Male USB cable. That should give you the clean slate you desire, but either method will likely work for you.
BTW For safety sake, remove external SD card or USB attached storage.Last edited by RISCy Dude; 13 July 2016, 04:43.
There are currently 2157 users online. 0 members and 2157 guests.
