Latest Updated Firmware for CSA91 based on Zidoo Full/Lite (Working Hardware Clock)
    Enjoy the fully working Firmware based on Latest Zidoo firmware for CSA91 or Equivalent
    (Fully optimized for speed)
    -- Latest Version --
    CSA91 - Krypton V4-FULL Firmware DOWNLOAD
    Rom based on Zidoo official version 1.0.45
    See Change log on Zidoo site
    Full Featured fully functional Functional.
    Latest Kernel
    Optimized Ram.
    Latest Security Patched.
    All Applications Updated.
    Pre-Rooted.
    Pre-Activated.
    Work for any R68/R8 or equivalent Devices with:
    Realtek RTL8723BS - WLAN 802.11bgn, Bluetooth 4.0LE, FM combo module.
    Realtek RTL8211E - 10Base-T / 100Base-TX / 1000Base-T LAN Compatible Devices.
    1G/8G Also Compatible.
    Hardware Clock Working.
    FOR OTHER DEVICES (RK3368 only):
    STEP 1 - Flash your device Resource.img after flashing the above firmware. Test if it works i.e wifi, Bluetooth etc if not go to STEP 2
    STEP-2 - Flash both Kernel.img and Resource.img after flashing the latest above firmware and test.
    (No guarantees on working of firmware on other devices)
    Zidoo has not updated its ZDMC version to 17.xx on ZIDOO X6 PRO. Let me know the stable Kodi or other build so that I can update in firmware.
    You can also install official Kodi build to test how it works.
    -- Previous Versions --
    CSA91 - Krypton V3-FULL Firmware DOWNLOAD
    Rom based on version 1.0.39
    See Change log on Zidoo site.
    CSA91 - Krypton V3-LITE Firmware DOWNLOAD
    CSA91 - Krypton V2 Firmware DOWNLOAD
    Rom based on version 1.0.38
    Minor Bugs Fixed.
    Optimize Zidoo Launcher to Speedup.
    Supersu Binaries Updated to Latest.
    Zidoo Updater Removed
    CSA91 - Krypton V1 Firmware (REMOVED)
    Flash with Android Tools 2.35 DOWNLOAD
    Please Note: After Flashing and booting for 1st time only **Wait for few minutes on the Language Select Screen** before jumping in. Let the Firmware complete the installation of all applications
    Further Optimization Tip
    Zidoo Firmware by DEFAULT "Windows animation scale, Transition animation scale and Animator duration Scale are set to 1x
    which is kind of slow. For best experience set them all to 0.5x From Developer Option you will feel the difference.
    - KrYPton
    -RK3368 CSA91/R8/R68 V2, V4
    Latest Updated Firmware for CSA91 based on Zidoo Full/Lite (Working Hardware Clock) by krypton
    Hi! You have more info for DTS-HD ? Work ?
    TRONSMART R68: Firmware "HPH NT-V8 ROM V1.2 (Dual-Boot) by mo123" (DTS-HDMA, Work)
    ONKYO: TX-NR 809
      Hi Thanks for this Rom it this still being developped? Just wanted to say i tried v2 of your rom on the same device your post http://freaktab.com/forum/tv-player-...device-r68-1gb shows R68. But Wifi wasnot working. I will try V3 now.
      PS I have the 2GB/16GB model
      Edit: Seems my Wifi has died, not even on original ROm the Wifi still working, Using your v3 now good performance, thanks
        Thank you so much for your work, I can confirmed it's working on I68G with recourse and Bluetooth fix.Every thing went well ,
        I tried many Roms for RK3368 this one is with amazing speed of internet ever
        But I I tried to install xposed modded which was working in many others but not this one yet! any idea?
          Not work on CSA91 , only put Zidoo X6 on the Screen but not Turn On
            It's OK, but the Rom is fast than other on my box still..
              i can flash with exit , now it's working Thanks
                Witam Jestem całkiem nowy tutaj
                Chciałem podziękować za świetne oprogramowanie, które zrobiłeś
                Zainstalowałem oprogramowanie na moim T051 - WORKS DELICIOUS !! ale to nie działa Wi-Fi i bluetooth
                Mam pytanie: mój T051 - to AP6330 - jeśli jesteś w stanie pomóc, aby mój sprzęt działaŁ z AP6330, czy ktoś może pomóc użytkownikom forum
                dzięki temu, co zrobiłeś daleko, pozdrowienia z Polski
