DoPo EM63 AML8726MXS change WiFi lib file
    Tablet DoPo EM63 board ID EM-M63-V1.1 . No Firmware from DoPo or support . Found a working firmware - em20140519 V002 ,Android 4.2.2 so far only think I see not working is WiFi . I need to change the lib ,ko file from 8723AU.ko to 8188eu.ko in the update.zip/system/lib folder and build prop so on so WiFi will work .
    Any Help or info on how to unpack repack the update /system/lib so WiFi will work or other ways to do it ?
    Thank You.
    Just a update- after a lot of searching around and so on I was able to root this tablet and copy 8188eu.ko file into the tablet system/lib folder but now do I get the OS system to see it & use it for say ??? Im thinking I need to edit some file to make it work ? Any Help on this ?
    Em63 Tablet WiFi chip is a Realtek -RTK8188EUS ------
    10-15-2015 update.
    I used Terminal Emulator to mount RW/RO and deleted stock file 8723AU -copy paste 8188eu to System/Lib and remane it 8723AU hoping to trick Android OS to see it but NO work !
    OK Guys/Girls need some help on this how can I make it work ??
    Thank You.
    Looks like this table will hit the trash can ---------- Next tablet I am thinking more on the line of Windows or just go back to a Laptop .
