New user and Minux
    New user and Minux
    Hi Gang,
    Well I joined and read the sticky's on where to look and how to post by Bob and Will and the welcome from Tatman65 but I still can't find what I'm looking for but I did D/L that android boot
    process post and the Kodi setup from TimACPR but I'm still hooped.
    What I've got is a Minix Neo 7 that I've had for quite a while and its always been happy ..... I just got back from, Vacay and now my unit is "no happy".
    When I power it up ..... the screen boots up and I see the Minux Logo and then it goes to start to load NitroTeam's Quickshot and gets so far and just hangs on the logo.
    It was happy and fine when I left for my vacation and it was on and powered up .... do you think I got hit by something nasty ?
    I guess my question is how can re-flash the unit from scratch ? And if so where can I get a current image and nice easy hand holding walk thru for dorks. That'd be a good book series BTW ....
    "Walk-Thru for Dorks" (grin)
    Cheers'
    BrainSample
    hey my friend and welcome to freaktab . this may be what you need . it has everything you should require to reflash your box . just double check to make sure it's the right one for you .
    http://freaktab.com/forum/tv-player-...inless-1-8-rom hope it helps
    freaktab art developer if you like my work please buy me a pepsi
      Hi tatman65 !
      Thanks for the help .... I'll go hit that thread and see what I can do !
      I hope I owe you that Pepsi ! (grin)
      Cheers'
      Brain_Sample
        Originally posted by BrainSample View Post
        Hi tatman65 !
        Cheers'
        Brain_Sample
        hope that lead you in the right direction buddy .
