OTT M8 TV box (S802) has flashing video if resolution is set to 4k
    Greetings......My OTT M8 S802 Cortex A9 Mali 450 box cant display 4k video.....When selected, the video flashes on and off, a big disappointment. I'm hoping a different firmware will fix the problem. OTT has no support .....or I just cannot find it.
    It's running kit kat, 4.4.2 When I try to flash a newer rom, the recovery halts and tells me the box is an n200 and the new firmware is something else. So I guess I need a compatible firmware newer than
    KOT49H.20150728 test-keys. Cant find it. help is appreciated.
