M8S+ won't turn on at all
I got an M8S+ from **** (picture of board attached). I flashed Openelec to it and it worked, but when I turned the box off, it won't turn back on. When I plug in the power cord, the blue light on the front just flashes and then goes out so it won't turn on at all. I've tried the toothpick method to boot into recovery, but no matter what I do, the box won't turn on. is there anything that I can do to get the box back up and running, even if it's with the stock image? I am a bit desperate here.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
I have the exact same board (starting to think this box is prone to this issue) and did the exact same thing. Have you found a solution?
If not I can help out but I only have a 5.1 ROM which means you will lose ethernet (WiFi still works), your remote wont work (I have a zip patch that gets the main buttons working) and when you turn the box off you will need to unplug it and plug it back in to turn on again. BUT at least the box will be working again.
There are currently 4212 users online. 0 members and 4212 guests.
