Sunvell T95X Amlogic S905X Android TV Box - 2GB + 8GB
    T95X 4K x 2k TV box is a media center which enables you to access tons of HD movies,
    ● Amlogic S905X CPU is rapid and stable which can give you a high-speed feedback and smooth response.
    ● 4K x 2K H.265 decoding demonstrates the high-premium visual effects.
    KODI 16.1 is designed for playing almost all latest audio and video formats.
    Android 6.0: Comparing to the former version, people can be easy to install or uninstall applications and games.
    ● 100M LAN can improve the net speed and the performance to a large extent.
    HD can reach to 3840 x 2160 pixel.
    ● It supports the 1080P / AV / Dolby / 3G which make you appreciate your entertainment time and splendid visual feast freely.
    Gearbest
    Does sunvell have firmware support with updates?
    Free 100Gb space for your files:
    https://degoo.com/g/Ov7nAz0
      None of the 905x have firmware links other then ota.
        Anyone have one of these on here?
        I'm currently looking for a second box and these are pretty cheap at just £26.22 at Gearbest.
          If anyone has one can you let us know how the WiFi performance is.
            I got a 1GB/8GB clone branded by another seller ... If you have watched the excellent redskull review on Youtube (https://www.youtube.com/watch?v=OlIwM8Sy2BA), it comes with a different launcher but, thx God !, exactly the same bugs. lol !
            - Poor simple band Wifi ( Unable to connect one of my network ...and i don't know why)
            - Multiple application crash
            - Google Play issue (you have to uninstall update)
            - At first boot, the box was in chinese
            Well, i can't find words to describe how funny is this little machine. But if you like pain and trouble, believe me my friends, you have to buy one !
              backorder . refunded . Shipped out I took a Mini II M8S 4K Smart TV Box Amlogic S905X 2/8 GB WiFi LAN 10/100 BT instead
              the sale has resumed $ 33.99
              Ships entre September 3 to September 14
                i uninstall all the apps i dont want from this rom and every time it reboots the apps get installed again... that sucks... I cant only stay with the apps I want...
                  Hi, I have this box with 2gb/16gb, I used es file Explorer & removed all traces of all the preinstalled apps. Which was mainly under system/preinstall I think.
                  Good luck
                    Hi, I also have this box, Sunvell T95X 2GB / 8GB. I have a question regarding the interface. I have noticed some buyers / other users of this tv box have a different (the one that I like the most) interface / home screen.
                    See attachment for the home screens. The first home screen with black background is the one that I have. But I would like to have the second interface, is this possible? I have a feeling that I might have the wrong firmware (not sure).
                      Do not buy this box. I have purchased multiple (3) and every single one is not without bugs and problems.
                      Here are only a few:
                      - The internals of the box are upside down so getting a *working* wifi signal can only be done by flipping the box on it's top which is a HUGE design flaw.
                      - There are errors with the play-store making it unusable
                      - The box is cheap and here you get what you pay for in this case, a cheap box
                      I would recommend a Mini M8S II on firmware rv_103 (because it is quite stable) as an alternative, it also has a S905X.
                      Hope this helps and wary buyers. All in all, DO NOT BUY.
                        Is it not possible to install stable firmware on sunvell box?
                            I have 1/8Gb version but it have the same problems. Not a good tv box. I recieved this box from banggood and it died after 2days (( I've ordered a usb male-to-usb male cable from aliexpress and was able to reflash it with custom rom img with my pc. I have my review videos but it's on russian. Video unboxing - https://www.youtube.com/watch?v=voRKuZFqSNc Video how to flash and review of custom firmware - https://www.youtube.com/watch?v=GWS73czKPwU You can find custom roms on 4PDA
                              link not working?
