Intel Core i7-6500U
The Intel Core i7-6500U is an ULV dual-core SoC based on the Skylake architecture. In addition to two CPU cores with Hyper-Threading clocked at 2.5 - 3.1 GHz (2 cores: max. 3.0 GHz), the chip also integrates an HD Graphics 520 GPU and a dual-channel DDR4-2133/DDR3L-1600 memory controller. The SoC is manufactured using a 14 nm process with FinFET transistors.
DDR3 16GB RAM, 512GB SSD
It boasts DDR3 16GB RAM, 512GB SSD, advantageous in performance, security and reliability, ascribing to the eMMC memory, ultimately delivering a richer end-user experience.
Gigabit LAN & WIFI
Gigabit LAN provides a data rate of 1 billion bits per second.
300MB Wifi with 2 Antennas.
mSATA and SATA
Geekbuying
