KII PRO Hybird STB DVB-T2 DVB-S2 TV BOX Android 5.1.1 S905 2G/16G 802.11AC WIFI LAN KODI Bluetooth
    Android 5.1 OS
    Amlogic S905
    Mali-450
    DDR3 2GB RAM, eMMC 16GB Flash
    IEEE 802.11ac
    DVB-T2
    Geekbuying
    Interesting with built in tuner hmmmm
      Looks nice. I ordered from aliexpress.
      I am waiting stable openelec or libreelec release for KII Pro
        I was thinking of getting one of these but I'd like to have 1000Mb LAN support. This unit is limited to 100Mb as far as I can tell - which means a botteneck if you have 300Mb fibre optic link.
          How ı can add k2 pro's wifi driver to libreelec or openelec?. Wifi do not work for me.
            Need firmware for this device IMG to flash via USB burning tool. If anyone have please to give me link?
            Regards
              here take it mate https://cloud.mail.ru/public/BA5h/W8wQZueLD
                Thanks tahir2007pk for response, i have this firmware , but is for install via microsd card or update via system. I brick my device with wrong firmware and now my device stop load after check DDR ( DDR channel setting: DDR0 Rank0+1 diff) , so need 1 file img firmware to flash via Amlogic usb burning tool and alive device.
                BTW, now PC can not see device, but after connect 29 and 30 pin eMMC and connect USB device response via Worldcup device and can flash.
                  Please information that is to pin 29 and 30 in Figure?
                    Ok,Ok,!
                      just have a look here at the CNX-Soft review and read the comments and you'll find a link for LibreELEC on this device
                        Dear kokovi4, could you please tell all user here how exactly did you unbrick your box. Where did you get the img firmware (KIII ?). I have marked the pins 29 and 30 an this picture more clearly: (is it correct?)
                        Click image for larger version  Name:	eMMC.jpg Views:	1 Size:	149.7 KB ID:	616182
                        Thanks a lot in advance.
                        edit: I've found the link for the firmware img file:
                        15/07/2016 Stock firmware for USB burning tool (* .IMG)
                          There is a very good custom rom from a Russian dev. :
                            Malaysk_KII_PRO_T2_S2_19_03_2017_v_4.5_DTV
                            Malaysk_KII_PRO_T2_S2_12_03_2017_v_4.2_DTV
                            Latest OTA Firmware
                            KII_PRO_DTV-ota-20161219.200139.V1031P3
                              is there any android tv rom for this device ?
