PiPO X10 10.8 Inch Z8300 Win10 & Android 4G/64G Tablet PC 802.11 b/g/n LAN Bluetooth 4.0 MINI PC
ID:	587737 Pre-installed Windows 10 & Android 5.1 Dual OS
    PiPO X10 is pre-installed with licensed Windows 10 home, so that our users are able to enjoy the advanced functions of Windows OS directly. Moreover, the built-in Cortana in Windows 10 can turn PiPO X10 into a work assistant as well as life-partner.
    Android 5.1 OS, rapid and stable, with a redesigned user interface built around a design language known as "Material design", avails the access to over 800,000 apps including Facebook, Youtube, Picasa and more.
    Intel CherryTrail Z8300
    Intel Atom X5 Z8300 has an average performing CPU with a maximum clock speed of 1,440.00 MHz. It has 4 core(s), resulting in extremely efficient multi-tasking when compared to dual core processors.
    4G/64G
    PiPO X10 boasts GB DDR3 RAM, and GB eMMC Flash, advantageous in performance, security and reliability, ascribing to the eMMC memory, ultimately delivering a richer end-user experience.
    WIFI + LAN
    Equipped with 100M LAN Interface for unfettered internet surfing.
    Supprots 802.11 b/g/n wireless standard, among which 802.11b has a maximum bandwidth of 11 Mbps, 802.11g 54 Mbps and 802.11n 150 Mbps.
    PiPO shows the latest intel mini PC X10 with 10.1’’ Full HD display at 1920*1080 resolution
    Powered by Intel Cherry Trial Z8300, 4GB RAM, 32GB or 64GB eMMC storage on board.
    Windows 10 home, 3*USB2.0 port, 1*USB3.0 port, built-in WiFi, 100M LAN port, HDMI, VGA port, with build-in 10000mAh battery with 6 hours battery life.
    Source armevices
