I recently bought a NEXBOX Z68 and the stock firmware was screwed up so I contacted the retailer and they sent me a newer firmware than anything I have seen here.
So I figured why not share it with the community.
after your update. could you check the version from setting. and how is performance with kodi. I am using nextlight 3b with spmc. if the new rom can use rtmc, i will try.
