QINTAIX Q912 Amlogic S912 –A53 2.0 GHz 2GB/8GB or 16GB 2.4/5GHZ Wifi, Gig Lan, BT4
    Amlogic S912 Octa-core Cortex –A53 2.0 GHz
    Octo-core Mali-T820 MP3 GPU up to 750MHz(DVFS)
    2.0 GHz
    2GB DDR3
    8GB/16GB Nand Flash
    HDMI 2.0
    5.8GHz and 2.4GHz,802.11 b/g/n
    10/100/1000M Ethernet
    Composite Audio /Video
    AV output and Optical output
    USB 2.0 host x 3
    Micro SD card reader TF card
    5V 2.5A power adaptor
    Android Version Android 6.0
    Menu Language
    English/German/Spanish/France/Italia/Nederland/Poland/Russia/Korean/Japanese/Simplified Chinese/Chinese-traditional
    System Upgrade
    Upgrade by Micro USB port
    Aluminum case
    Thanks to Qintaix we have the NEW Q912 Amlogic, Good looking unit, Solid all metal finish and a Display you know you want one now
    Few Happy Snaps to get things started,
    Firstly the Wife thought I got her something sweet when her eyes set upon the box.
    I said sure it's sweet (for me) have a look, luckily I am good catch is all I can say.
    HDMI 2.0, 5.8GHz and 2.4GHz,802.11 b/g/n, 10/100/1000M Ethernet, Composite Audio /Video, AV output and Optical output, USB 2.0 host x 3
    All the bits required to make it happen on the Telly
    Further Testing has progress
    Benchmarks and performance is on par with other S912 I have tested.
    The Down Side is there is only One Antenna Connected, other there for looks .
    In saying that the performance of WiFi is OK, but Two is always better than One in high traffic areas.
    Second there is no Ethernet on this particular unit due to early release of this product, and I hope to have this looked into shortly.
    Unit Looks good performs on par with others I have tested, despite the minor niggles,
    Not suffer from over/excessive heat problems
    More to Come.
      A few benchmarks, you will see much the same as other S912.
      Good Looking UI Easy to use with remote or Keyboard
      You can see full listing of Benchmark Score> http://browser.geekbench.com/v4/cpu/4159
      And Here > http://browser.geekbench.com/v4/compute/2416
      Vellamo and Benchmark scores
        Images of the PCB
          How is the video & wifi performance of this device?
          Is it able to play all types of video & also the HDMI passthrough is working?
            @mulderfox No new firmware as yet available,
            Performance of the Qintaix Q912 is on a level playing field with other media 912 media players.
            Cheers
              A firmware update this day, no change log as yet,
              Unit performing well with daily use, like most
