(Help) T95N Mini M8Spro 2G Stock Recovery?
Hi, I tried flashing a twrp recovery to my T95N Mini M8Spro 2G box and it seems to have gone wrong and now I have no recovery to boot from. I did not make a backup of my original recovery. Does anyone have a backup of the stock recovery for this device? Thanks for your time.Tags: None
You can download the firmware by this link:
Bootcardmaker.exe:
https://www.dropbox.com/s/qkgzmtzsw9...Maker.exe?dl=0
Manual:
https://www.dropbox.com/s/oqbtas3e4l...nual.docx?dl=0
This is Current July 2016 factory Firmware for this box.
After that i can give you a working TWRP zip to flash from external sd card.
Let me know.
Originally posted by G.Apellaniz View PostHi Kostaman, Please shere the recovery for the T95N, Thanks!
See Link
Hello All
I bought TV Box T95N Mini M8Spro from this site
http://www.aliexpress.com/item/New-T...670305568.html
I want to update new soft (Android 6) and I found from other site image. I installed according to the instructions. During installation an error occurred, and small light turnd red. After that, my TV Box didn't work. When I want to power on, only light turn on red.
I think that, I have iInstalled wrong image. Probably to mini M8S, not to M8Spro. . Could I do something with it ? Please help ....
If you were using Android 5.1 before , You have the S905 chip.
You might have flashed the wrong image.
There is a difference with the device trees.
Check carefully what you have .
Originally posted by kostaman View Post
Do you have the S905 or S905X Chip. ? Were you using Android 5.1 before you tried to install Android 6 ?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
I don't checked in settings, but on BOX write OS: Android 6
That image you got fro where ?
You must flash the MiniM8SPro S905X firmware. Not anything else like MiniM8S II which i think you have done.
Sorry i have the MiniM8sPro S905 and cannot help you.
It is a common box but with this new S905X chip it is pretty new.
These boxes generally update OTA or at lest the s905 i have does.
You will have to ask the seller for a link to your box's firmware.
Okay you have the S905X Chip.
I will find image to MiniM8DPro S905X, and when I found i paste the link, will be for others users. Also I wrote message to seller maybe He/She have, but I doubt. ... because He/She only seller/distributor ...
Thank You for reply...
I will find image to MiniM8DPro S905X, and when I found i paste the link to others users. Also I wrote message to seller maybe He/She have, but I doubt. ... because He/She only seller/distributor ...
Someone might read these posts as well and help you.
Good luck with it.
Do You think that I will found firmware for MiniM8S II with s905x my box will be works ? or Have I looking for only firmware for MiniM8SPro S905X ?
I want to return to the topic of our conversation.
You have nothing to lose.
Can you get into recovery using toothpick method ?
Try that first and see if you can Factory reset. I'm not sure how far the attempt to flash wrong image went.
Can you write something more about toothpick method ?
Insert toothpick into av hole and press to feel a click. Test pushing toothpick into av hole to feel a click. That is the reset switch.
Press it in until you feel click. Then hold it in after it clicks.
At the same time power the box on and wait for box to go into recovery.
You should boot into recovery with this method.
Turn off box from power.
You should boot into recovery with this method..
Now i must attempt connect PC with my box - USB men / men. .. .
One quesstion, I read on this forum more post, where users modify the device in the open box in proccesor wires etc... What is it for ?
There are currently 1875 users online. 0 members and 1875 guests.
