Tanix Pro Flipper Rom based on latest stock (all credits to Builder Of the Amilogic tool)
    Ok its uploading now but heres the credits
    Reboot app - Petrus
    special Thanks to everyone who endured my questions not limited to Pharjister,superceleron,Louis and Abdul
    If I can do these changes then anyone can. Proof you can teach a dirty dog new tricks.
    Changed Boot Animation - Name Filpper (Credits to maker on Xda boot animation site)
    Removed bloat- stock launcher and added few programs and removed tvaddons and added link in kodi to Beyond builds. New wallpaper and feww other items. Will be adding more as I learn to do more but been a fun day. (Its not only fun when it works as it should its fun finding out what you screwed up too...
    Posting link once its finished uploading - still working on task bar i got ui to boot and its from another 905 device so i know its there now to find whats making it not work lmao..... Please let me know your thoughts
    Wait for the Dolphins to stop swimming and set up will start... Watch carefully normally six shark sightings then it boots, Back to one after first boot....
    Standard Disclaimer If your tvbox starts talking to you or starts changing stations none of this is my fault even if you brick it thats still not my fault.
    Updated to Pharjisteers latests fixes added
    new wallpaper.
    media apps.
    cleaned Kodi.
    Added Program Files for Ares and Beyond Builds
    Added Freaktab Logo to Kodi startup screen.
    free streaming apps.
    changed boot animation to 10 fps.
    Flipper 2.0
    You may only view thumbnails in this gallery. This gallery has 4 photos.
    From the sounds it seems this may also run on the m8s mini 905x. I have that device ill try it tonight and see what workes or does not.... 😁 Then we know for sure Rooted on mini works too.
      Iv tested the TX5 pro on the m8s mini ii & all seems to works well so far just downloading The flipper pro going to give that a blast
        I've been messing around with the AMLogic tool too and it's very useful.
        Will give it a try on the TX5 Pro when I'm back tomorrow.
          Tried your rom on tx 5 pro but my box would not power on luckily I was able to flash stock again.
            I installed it to the TX5 Pro and it booted up fine.
            What I have found is that after flashing, the first time that I plug the ac adapter in there appears to be no power but pulling the plug and re-inserting always does the trick.
              Thanks I thought I bricked the box when their was no power,how is kodi with this rom? I get lot of buffering which I don't have with beelink i68 running same setup and kodi hangs a lot
                I've only done basic testing of the bundled Kodi but found it pretty good overall from a perspective of consistency of play.
                I did notice that at certain points that is could suddenly crash but not whilst playing, only when altering settings.
                There is clearly work to be done as there is with any new box.
                SPMC might be more suited as I believe that there is more chance of a little AMLogic love being applied to the fork.
                  Still playing with the tool and will include spmc in next build as well as few new things i just learned to apply. 😃
                    can someone point me to where and grab the original tx5 pro firmware? I need a backup just in case. Thx.
                        Found disable amcodex in kodi resolved any crashes.
                          What box you use... I tested again on 3 i have. Worked..
                            Tanix tx5 pro
                              Working on Tanix pro just re tested it again.. Loaded onto both just to make sure. 😁
