Nexbox 809VI 4k TV dongle
    I recently purchased one of these link http://www.inexbox.com/nexbox-809vi-...ongle-in-2016/
    I found stock firmware for it here link http://chinagadgetsreviews.blogspot....-511stock.html
    They refer to it as an MK809VI.
    My only issue with it is that the play store keeps crashing does anyone else have one of these or know of a device with identical hardware that I can get roms from? I would like a Marshmallow rom but I see that there is only one of those for this chipset RK3368.
    Thanks for the help and guidance.
    Also could we please get a subforum for this/these devices?
    Check if the datetime on your device is correct. I have seen issues where this used to crash Play store in my box earlier.
    Tronsmart Orion R68 Meta
    CS968 -> HTC_T018 v4 20131216 with MTK
    GM282 (aka CX 919 II aka J22) - dead
      Thanks for the quick reply... My time was wrong, but I fixed it and even rebooted but I still get the same error. "Unfortunately, Google Play Store has stopped." It just keeps saying it every few minutes.
        It appears that this device uses a RTL8723BS wifi chip. At least according to the kernel logs.
