OTT M8S+ (s812_M8_REV1.1) correct firmware?
    Hello all,
    The led on my device glows red and it doesn't show any signs of life. I tried the sd flash procedure with the toothpick method - no result what so ever. I tried also the USB burning tool method - it starts the process and stops at 2% with the "USB Control Setup Error". I presume I'm using the wrong .img file. Can you point me to the right one for this particular model.
    I'm attaching two pictures from both sides of the PCB. Wifi chip is AP6330
    Thank you all in advance!
    I have the firmware for ott m8s+
