Launcher - TX5 pro S905X Android 6.0 tv box
That is probably because there are some required libraries and config files that are baked somewhere in the ROM that are required to run the launcher.
This is quite common.
I've just had a look and I can see some other things linked to it but if you are just wanting to run the apk then they won't be of any use to you.
There are currently 1959 users online. 1 members and 1958 guests.
