Since recieving my MK809II i am striving to get a working XBMC install on 1080p resolution using it's native player.
So from start i have flashed a lot and inserted and removed my powered USB hub a lot of times.
I also have installed heatsinks and cut holes in the housing
Here is the problem i have run in to; the standard USB port does not send and recieve data anymore
If i plug my air mouse reciever into it, it is not recognised. And same happens with the other peripherals.
When i plugin another usb hub, not powered, the on/off light turns on so the port still provides power.
Perhaps the solder is somehow scratched by removing the housing? Looking at it i cannot see any damage but as i have no micro electronics knowledge that does not say a lot.
Attached are some close up photos but the fine detail is not visible off course. But perhaps someone can point me to a spot where to look more closely?
I have bought a micro usb to usb female adapter for use on the otg port and doing so can continue playing around. But it would be nice if someone has an idea how to fix it.
Things i have done are reflashing a normal non overclocked kernel Imito Finless 2.0 ROM and the 1.7a version. But no result.
Making sure i have enough power for the stick; i use a 5v 2100mA ac plug for the stick, and the powered USB hub gets 5V 3A using a phillips ac supply.
Attached are some photo's of the stick including heatsinks and active cooling. And yes i have used LEGO to build housing for the stick, 3 fans, usb hub and place for the excess wiring as i have no experience soldering and 3 plastic containers were destroyed in the process.
