H96 PRO TV Box Amlogic S912 Android 6, 2/16gb or 3/16GB, Dual WiFi, Gig Lan, BT4
Originally posted by Terence_G View PostI purchased 10 of these boxes from DH Gate and they have the 20161101 firmware on them. I have had issues with the wifi not working properly and have been trying to update the firmware since I received them. They sent me a link to download aml_s912_q6330-H96-PRO(3+16-kodi16.1)-mac-20161105.rar (This unzips to a .img image file) which is apparently the newest firmware and also a link to a card burner to create a bootable sd card. I've tried repeatedly to update but am not getting anywhere. Here are the steps I've taken to install this firmware, can someone please tell me if I'm doing something wrong?
1) Unzip the rar file
2) Insert the SD Card into the PC
3) Run the card burner which formats the SD Card and installs the image file onto it.
4) Install SD Card into the tv box.
5A) Tried using the update app and choosing the local install option but no file is available to choose for the update.
5B) Tried installing SD Card with no power to the TV box then powering it up with the reset button pressed but all I see is an Android Guy with a red X on his chest. I did this because I read somewhere that you have to go into recovery mode to initialize the firmware update.
Obviously I'm doing something wrong and hope someone can help.
One other note, if I double click the image file on my PC it tells me it's corrupted.
Thanks,
Terry
or try burning the image file using diskimager or rufus
Note, is you use a burn the image, it can't be seen by windows, that is normal.
sorry if this is a bit vague, I have only updated images on a Geniatech Mygica 510b. with that, I just copied the img file to a FAT32 formatted microsd card, went into recovery selected the img file.
Originally posted by BanziBaby View PostHi,
Can anyone tell me where you get the latest firmware for the 3GB version of the H96 Pro? The online update in Update & Backup doesn't work & using the wireless update finds nothing either.
Originally posted by bubblegum57 View Post
There is a cpuz app that can give you details, the link is the previous page to this post.
Originally posted by ttaidapos View Post
11/18 is the latest and extremely hard to find. The one on the link is 11/01
Yeah but that firmware is for a different chipset, it's the Q6330 one I looking for & not the Q9377 one. I get the feeling that as none of the firmware update functions builtin to the firmware work I have pretty much wasted money on a box that isn't going to get updates.
I couldn't get it to work.Last edited by bubblegum57; 04 January 2017, 23:01.
I found this http://4pda.ru/forum/index.php?showtopic=765001&st=320 on a Russian website
If you go to the comment section of the link below there is a user (chaos2go) posting information on the firmware as well as links to where they've uploaded updates.
I'm having issues with my H96 Q6330 randomly flashing green on the screen. I may try one of their firmware updates, but I am a bit hesitant.
Originally posted by Kry View PostIf you go to the comment section of the link below there is a user (chaos2go) posting information on the firmware as well as links to where they've uploaded updates.
Cheers, I read all the comments but the only firmware he mentions for the q6330 version of the box is the same firmware it ships with, all the other firmware he posts are for the q9377 version which would kill wifi & bluetooth on the box.
There are currently 43065 users online. 0 members and 43065 guests.
