SUNHED S3 Media Player HiSilicon V200, Android 5.1 2/8GB, Sata, Dual Wifi, Gig Lan, BT4
    Features
    SoC - Huawei HiSilicon HI3798C V200 Quad-core 64-bit high-performance ARM Cortex A53 with NEON
    GPU - Mali-T720 with OPENGL ES3.1
    RAM - 2GB DDR3
    Flash - 8GB eMMC
    OS - Android 5.1 running on 1080P UI solution
    10/100/1000 Lan, Wireless LAN - 2.4GHz / 5GHz 802.11a / b / g / n / ac external antenna.
    Bluetooth - Bluetooth 4.0 EDR
    HDMI - HDMI 2.0a
    4K2K, H.265 hardware decoding
    Imprex 2.0 Processing Engine with HDR (support video post-processing advanced setting)
    7.1HD Audio passthrough and downmix: Dolby Digital Plus, DTS-HD
    3D Bluray subtitles
    BD-ISO and 3D BD-ISO
    2D / 3D Games
    USB mouse and keyboard operation and 2.4G QWERT Remote
    Remote wakeup and standby via ethernet
    Firmware local update and OTA online update
    SAMBA, NFS network playback
    Remote control with mouse function for use by all Android apps
    Video - 1x HDMI 2.0a, 1x CVBS
    Audio - R / L stereo, SPDIF optical, SPDIF coaxial
    2x USB 2.0
    1x USB 3.0
    1x Built-in SATA interface
    1x TF card slot
    Input: AC100-240V, 50 / 60Hz
    Output: DC12V / 2A
    Accessories
    1x Power adapter
    1x 33-key Infrared remote control
    1x HDMI cable
    1x SATA cable
    1x User manual
    Source CNXSoft
      Thanks to Sunhed Delivery today of S3 Media Player, my first Hisilicon model so we a few pictures to get started
      Features
      RAM - 2GB DDR3
      Flash - 8GB eMMC
      HDMI - HDMI 2.0a
      3D Bluray subtitles
      2D / 3D Games
      2x USB 2.0
      1x USB 3.0
      1x TF card slot
      Also what else is in the box,
      Output: DC12V / 2A
      Accessories
      1x Power adapter
      1x HDMI cable
      1x SATA cable
      1x User manual
      Well Presented, Quality HDMI cable so looking good.
        How is the performance of this device? Please post the review of this device. I have heard good things about these HiSilicon based players. Where did you purchased this device and what is the cost?
        Sent from my HM 1S using Tapatalk
          Sunhed S3 Interesting Media player indeed
          A few early problems cause by my own curiosity, but all up and running now.
          A Quick look at the UI/Launcher and some of the Extra settings to be found and most likely a few more I am yet to find.
          Also has its own set of menu functions that you can to to easily do some quick settings to save wondering though Android menu's
          Very well presented Unit as seen above and can easily play most files I have throw at it so far quite well
          How good Kodi will play, I am not yet convinced, but that is a later problem
          First, will do the Basic Bench test and performance, Just to get the numbers.
          Look at CPU-Z to see what is going on the Inside
          Geekbench4, Compute Score, read the full details > http://browser.geekbench.com/v4/compute/38468
          Geekbench 4 CPU Scores > http://browser.geekbench.com/v4/cpu/175231
          SUNHED
            Today I have connected an MSata thru a converter to the Sunhed S3 via SATA, copied a few files 4k Samples across thru windows to HDD easy as thru Windows explorer.
            Recorded for the sake of recording , artifacts or crud would be produced by the conversion.
            In saying that on my 28 Monitor 4k @ 60Hz they're Excellent,
            I was using using the inbuilt player, click and play to easy. Either Via HDD or USB3,
            Kodi at this stage not to happy with these 4k Demo's etc so far, something I may look into.
            Sunhed
