Minix A2 Lite remote with JUSTOP Android 5.1 Amlogic S905 tv box
    Hello. I have bought a Minix A2 Lite remote for my (rooted) JUSTOP Android 5.1 Amlogic S905 tv box.
    While it works fine for the most part, the power button however, don't. The button uses IR while the rest
    works with the usb receiver. In the remote.conf I've changed the factorycode to match my new remote
    and I'm able to map the powerbutton to key 116 POWER. But that just opens the power menu in android,
    and I can't turn the device back on that way.
    The weird thing is that the power button on the original remote still works, while the rest of the buttons
    have been disabled, as they should. Is the power button configured in some other file or?
    I've spent all yesterday trying to get it to work, as I would like to avoid having to use 3 remote controles >.<
    I hope you have a solution to my problem. Thanks in advance!
