Edit mtk EBR files
    Edit mtk EBR files
    ADMIN note:
    !!!!!... This operation will delete all your installed apps on phone,
    and also delete all files in the internal SD card
    so, before proceed,
    Copy all your data to PC or to external SD card.
    If you have a CWM/TWRP recovery,
    do a full backup from recovery to external SD card.
    To use this tool, you need the 2 file EBR1 and EBR2 from your current ROM only.
    Before use on your phone, be sure the initail value in box "USERDATA size"
    is exactly your current /data partition size,
    do not use this program if don't match.
    I am only test on my MTK6582 tablet ,no any problem.
    Chganelog:
    Version v02.00
    Add support for only EBR1.
    Version v03.00
    Add support for another type of MTK with only EBR1.
    Version v04.00
    Add support for another type of EBR2 table.
    Download link
    https://drive.google.com/open?id=0B3...1R1VEc3VnBNWHM
    Dos interface version (v1.0.1)
    Download link for Dos version
    https://drive.google.com/open?id=0B3...DdSc1F1bkxiS0k
    Hello thanks for the program. I'm using ver 4. It shows 924MB user data. Actually there are 2GB that I want to increase to 8GB.(it is 32GB tablet with MT6582 and KitKat). Should I put 8192MB or multiply 924MB(actually 2GB) by 4. Thanks for help.
