Tanix TX5 Pro Amlogic S905X 4K KODI 2G/16G Dual WIFI Fast Ethernet + BOW BT Keyboard
    Look and review of the Tanix TX5 Pro 2/16, Dual WiFi Currently
    Also going to use it with BOW BT Keyboard/Touchpad looks a bit like a K400r
    A much better keyboard layout I feel as I will show later
    So let's get started.
    Switch on No worries, Switched on BT scanned for items, Hold Function and C key and keyboard connected, easy.
    Will be using keyboard to do all setups etc, set up email and google accounts ok,
    there is a glitch in this version of Rom and I see there is an update to fix all this, so next thing is to update the box
    Keyboard works well and the boxed switch on.
    Different UI and looks very clean, Like it.
    A Few Happy Snaps
    And The BOW Wireless BT Keyboard
    As you can see the keyboard layout in the lower Right is much better spaced that the logitech k400
    Larger Enter/Shift Keys and cursor keys not all bunched together.
    Works both Android and Window, has no English instructions for working out what controls what appears to be a few settings, icons should be self explanatory enough we hope.
    Update done now running Android 6 Hmm thought it was going to be 5, never mind is what is,
    Re-setup all appears Ok, we will see how it all goes before jumping on to the Zombie, Frankenstein or whatever its called rom its called that the locals are working on
    Cheers
    MTC.
    Bit of a look see of what on the inside..No ventilation to speak of
    Thermal Pad from CPU to Metal plate seems to work so far.
    mTc
