Android 5.1 H.265 PowerVR G6110 2GB DDR3, 16GB Rom Bluetooth 4.0
Hi Guys & Girls,
This review is for the New coowell v4 Powered by Rockchip 3368 Octa Core 64 Bits GPU
A Big thanks to Gearbest For the Review sample
Right lets get this started,
The Coowell v4 arrived to me in the uk in 6 days via DHL with £17 having to be paid to customs this time (A lot this time but different every time) So if you're not in a rush for the box & to avoid customs charges your best off going for the free postage option.. Yes sometimes its slow but it does seem to have got better in the past months.
The V4 was very well packed in a strong plain brown box & the V4 was in another box inside that one.Iv doine a basic unboxing video i will add it to the end of the review.
The V4 comes with the rockchip processer RK3368 Octa-core & is a smart looking device & not too big, It Comes with a sneaky pop up camera (Like it).The box has 4 rubber feet to stop it sliding around the desk,Vents on the button to help draw in the cool air & a A recovery button you can easy get at,Power button on the top ,IR receiver & microphone on the front,On the left hand side we have the Sd card slot & one usb port,On the rear we have the wifi anteena,RJ45 port,usb port,SPDIF,Mini HDMI,otg,AV out & the power port.
The Coowell also comes with an IR remote :-( I so hate using an IR remote on a TV Box So throughout this review iv bee testing out the IpazzPort 2.4GHz Wireless hand-held touchpad multimedia keyboard
A Great alternative to the stock remote but does NOT Come With the V4
Once connected up to the TV press the power button & enjoy as everything seems to work very well the V4 boots up in less than 30 seconds,
Both top and bottom status bars are there and the box is rooted :-)
The UI is very smooth and responsive going back and forth through apps, im loving this box so far
It comes with 3 launchers pre-installed So we have a good starting point
The V4 does get warm but no where near hot
The standered android launcher,
MediaBox launcher
Launcher
Games
Iv tested both beach buggy blitz & Asphalt 8, Both played perfect with no crashes or lag,The game loading time is also very fast Iv tested both the Tronsmart Mars G01 gamepad & my ps3 sixaxis controller Both worked fine & no bugs with the sixaxis gamepad either.
Kodi
Iv been using the V4 for a week now as my main kodi tv box & i have to say im very impressed streaming 1080p no problem at all,But kodi does take a while to shut down about 10 seconds i would say
Misc
The 2MP Camera pop up camera works great tested on skype works perfect
External non powered 1TB samsund HD works
Tronsmart Mars G01 Gamepad works
Sixaxis Ps3 controller works
32GB works (64GB dont)
Play Store Working fine
Bluetooth working fine
Internal Photos
Cpu Z
Antutu video
COOWELL V4 TV Box with Camera Dual Band WiFi
COOWELL V4 Features:
Android 5.1 Lollipop OS System (ROOTED)
Featured with the Latest Android 5.1 Lollipop system, this TV Box is more stable than Android 4.4 operation system. You can access to thousands of films, TV, Live Sport, Music and more with COOWELL V4 smart TV Box.
Rockchip 3368 Octa-Core CPU
Powered by Rockchip 3368 Octa-Core 64Bits, COOWELL V4 smart TV Box is a HD media player with SGX 6110 high performance GPU (supports OpenGL ES3.1) that can reach speed of up to 1.5GHz.
HEVC H.265 & 4K High Resolution
H.265 decoding occupies less bandwidth (about 50%) than H.264; True UHD 4K * 2K enables you to watch your favorite movies and live streams at vivid and smooth playback, which is 4 times of full HD 1080P.
Large Capacity & Wireless Connection
The reading and operating speed is faster and more stable with 2GB DDR3, 16GB EMMC; 2.4G & 5G dual band Wi-Fi, 1000M LAN and Bluetooth 4.0 make home entertainment become easy
Preinstalled Kodi 16.1 RC3 & 3MP Camera
Preconfigured with XBMC / KODI, you can download numerous add-ons, like YouTube, Netflix, FaceBook, Twitter, Skype and more; 3MP camera and high-quality Mic support Video Chatting
Specifications
General
Brand: COOWELL
Model: V4
Type: TV Box
GPU: PowerVR G6110
System: Android 5.1
CPU: RK3368
Core: 1.5GHz
RAM: 2G
ROM: 16G
Max. Extended Capacity: TF card up to 32GB (not included)
Color: Black
Media Supported
Decoder Format: H.264,H.265,RealVideo8/9/10
Video format: DAT,H.264,H.265,ISO,MKV,MOV,MP4,MPEG,MPG,VC-1,WMV
Audio format: AAC,FLAC,MP3,OGG,RM,WMA
Photo Format: JPEG,JPG,PNG
Product Details
Bluetooth: Bluetooth4.0
Power Supply: Charge Adapter
Interface: HDMI,RJ45,SPDIF,TF card,USB2.0
Camera : 2M
Language: Multi-language
Firmware Information
Firmware Version: Android 5.1
Firmware link coming soon
Power Requirement
Power Type: External Power Adapter Mode
Power Input Vol: 5V
Dimension and Weight
Product weight: 0.141 kg
Package weight: 0.608 kg
Product size (L x W x H): 14.00 x 9.20 x 1.80 cm / 5.51 x 3.62 x 0.71 inches
Package size (L x W x H): 23.20 x 14.20 x 5.50 cm / 9.13 x 5.59 x 2.17 inches
Package Contents
1 x COOWELL V4 TV Box Rockchip 3368 Octa-core
1 x Power Charger Adapter
1 x HDMI Cable
1 x IR Remote Adapter
1 x AV Cable
1 x User Manual
Basic unboxing video
