SCISHION V88 PRO Amlogic S905X Quad Core, 1/8GB, 2.4GHZ WiFi, 10/100 Lan, BT4
    Scishion V88 PRO Amlogic S905X, Mali-450, Android 6.0 1/8GGB
    Bluetooth: Bluetooth4.0
    Interface: AV,DC Power Port,HDMI,RJ45,SD Card Slot,SPDIF,USB2.0
    1 x SCISHION V88 PRO TV Box, Remote Control, HDMI Cable, Power Adapter, English Manual
    Gearbest
    Coupon: GBV88P
    A few bucks of well $4.84 ?
    Did anyone tried out the AV jack?
    My device seems to have a shortage between audio left and ground. One other user said he has the same problem.
    Can you confirm it is a hw assembly / design flaw? If yes, do you have an idea how to fix that?
    update:
    i was completely wrong about that.
    The av jack has a special layout. I read 4pda that yelow video and red right channel is mixed up. But maybe it is more different. i think from the cable to top of the jack: ground- left - video - right would be the layout. So it won't work directly with a headphone, it needs an adapter cable anyways.
