Defective AV port on an MXQ Pro?
I have a 4K HD Smart TV Box S905 MXQ Pro unit and believe its AV port is defective. When I connected the AV port to 3-RCA ports on my old TV set using this 70 CM 3.5MM Jack to 3 RCA Male Plug cable (came with a Z4 L 64-bit RK3368 Octa Core Android 5.1 Lollipop TV Box), the video looks out of sync in Black/White. If I replaced the MXQ Pro TV Box with my Z4 L 64-bit RK3368 Octa Core Android 5.1 Lollipop TV Box, the video is OK. So, this proves the 70 CM 3.5MM Jack to 3 RCA Male Plug cable is OK. Has anyone here encountered this issue and knows how to fix it?Tags: None
Originally posted by trebor View PostCould be a NTSC/PAL thing coming from the box also try lower resolution
There are currently 2312 users online. 1 members and 2311 guests.
