KM8 Amlogic S905X Android 6.0 Marshmallow KODI 17.0 TV BOX 2G/16G 802.11AC WIFI LAN Bluetooth
Here I have the KM8 905x 2/16, this one is not happy chappy at the present, lots of Launcher has stopped errors happening.
Certain Graphic test are just dropping to a Purple or Green screen, Power Of and start again
But we will continue with a bit of a look see.
Small Compact Unit, with the Multi Regional Power Pack, Looks ok remote works well all the bits you need.
Benchmarks for the KM8 Amlogic S905X Android 6.0 Marshmallow KODI 17.0 TV BOX 2G/16G
Full Scores can be found > https://browser.primatelabs.com/geekbench3/7940514
The KM8 is a 905x 2/16GB unit the supplied Android 6.01 software is ok to a point until it crashes at odd time.
I am not sure what causes this crash will have to run some logs and see if those in the know can sort it out.
As this is a first release and like most so far, none have got it 100% right first time out.
Setup was easy login to Google etc no problems found.
It can do the most things fine and performance is good in all test used.
WiFi and Ethernet was ok with speeds pending on the time of day and how much traffic in the area.
It will play most video's fine and game performance is fair to good, like other 905x
The 905X is the cheaper cousin the the s905 so the performance is not as strong.
Time will be the test of this device small and compact and some creative rom work should improve its performance.
There are currently 2036 users online. 1 members and 2035 guests.
