OK?????? but what am I supposed to do?
Freelander PD800 RileyROM 1.0 [Feedback]
Just download the ROM again and flash as you did before...just use the new zip instead.
You shouldn't get the error again.
Just look over the readme and First Time User Guide.
Good luck.
RandyRandy
Originally posted by rrileypm View PostJust download the ROM again and flash as you did before...just use the new zip instead.
Good luck.
Randy
Still getting download file failed error.Last edited by circusboy; 22 July 2013, 07:19.
The official site for ROM updates is: http://223.4.236.214/bbs/showtopic-13607.aspx
There are two versions there:
Alternative link (probably faster download) for the English versionPD800(中文版)= Chinese Version PD800162 2013年5月 http://pan.baidu.com/share/link?shareid=466502&uk=2956444697&third=15 PD800(英文版)= English PD800162 2013年5月 http://pan.baidu.com/share/link?shareid=466498&uk=2956444697&third=15
you will also need the Rockchip batch tool 1.7
I used this guide It's for a different tablet but same proccess
Originally posted by Glouds View PostThe official site for ROM updates is: http://223.4.236.214/bbs/showtopic-13607.aspx
I used this guide It's for a different tablet but same proccessLast edited by circusboy; 22 July 2013, 17:23.
Are you still having problems after I updated the parameters? I'm not sure what's causing this.Randy
I will look a little more on my end, but it should flash OK since I redid the parameter files.
I do not have this tablet, so your testing is greatly appreciated.Randy
One thing you might try, if you have time...on the Flash Tool supplied in my ROM...right click in the white space at the bottom and "add item". On line 8 in the Name field type "backup". Leave the address and path fields blank...and keep it unchecked. Then flash.
I haven't run into any problems with the 3188 ROM's with this, but on the 3066 ROM's this entry had to be in the Flash Tool or it caused errors.Randy
Originally posted by circusboy View PostI used Glouds links and got my tablet back to stock. No sure why yours wouldn't work. I may try again later.
But thanks...I really appreciate any cook!
Originally posted by Glouds View PostI currently don't have the tablet on me (gave it to my sister for a month) so I can't try the RileyROM myself... All I can say is that the stock ROM is bulky. Please share your experience with this one
There are currently 2726 users online. 0 members and 2726 guests.
