Please help to find the NAND chip location
The attached photo is my Amlogic S812. I was trying to the bring the dead (no red or blue lights) or bricked device back to life as I mentioned in my other post. As the toothpick reset does not work I would like to try NAND pin shorting method. Could you please help me to identify the NAND chip and pins location from the attached photo.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
Originally posted by kevin1341 View PostHi mad2016 try this.
[ATTACH=CONFIG]n593110[/ATTACH]
Load USB Burn Tool with the firmware.
Short these pins out with USB Burn Tool Started.
Connect box with USB cable.
Good luck
Cheers
Kevin
There are currently 2094 users online. 1 members and 2093 guests.
