Will there ever be a android 5.x rom?
As possible upgrade path for your s802...i suggest OpenElec or Libre-Elec, if your device is supported (I did this on the s89 and s805 works really well )
goodluck
*As for the Amlogic S9xx , I would suggest holding off... As CNX site reports...Amlogic scaming\fake performance issue's (and trebor has a s912 running at 91c while benchmarking)
I might port one over after 905Bugs are Sons of Glitches!
JustMe
Originally posted by JasonZech View PostWill there ever be a android 5.x rom for these s802 boxes?
s905 runs LL, but weaker s905x runs MM. You want to run MM ? Buy a new device. Chinese marketing
Rant over
s802 running LL is a question of a having someone with the will,device and source code to do it. Someone outside the loop of interest. There are LL rom's for the s805, and they run better than KK, so LL in s802 is perfectly possible also.
JustMe will do it
There are currently 2523 users online. 1 members and 2522 guests.
