8 minutes ago
I've tried every method to root for this Amlogic S905 device with no success.
It's running Android 5.1.1
All the one click root apps fail.
I've tried the EZ root method with every option given in the forums.
The closest I got was by deleting all files apart from the EZ root zip which I have also renamed to update.zip.
The image shows the closest I got to getting root.
Before this method I was cache and failed to mount errors etc
Tried using 32gb micro sd fat32 empty apart from the nedeed file.
Also tried using usb drive but that wouldn't mount.
I don't have access to a pc for a while so stuck with this box and android phones and tablets to attempt for root.
Image says E://failed to verify whole file signature.
Signature Verification failed.
Installation aborted.
