New arrive PIPO U8 !!built-in the first Children Launcher of Android tablets
    New PIPO U8 launched officially. Besides outstanding performance, the unique Children UI has attracted plenty of parents.
    In addition to its unique and friendly PIPO UI, PIPO initiates Children UI exclusively. Children UI is under PIPO family launcher. It is easy to switch from PIPO UI to Children UI. The Children UI, designed to guide children’s education, learning, growing & playing, is cute and colorful carton design. Parents can set up the lock, password and play time limit by clinking Parental Control center in the upper left corner. Learning and playing time can be controlled by pre-set time limit.
    ● Display: 7.9", 1024*768 IPS (4:3)
    ● Touch Panel: Capacitive 10-touch
    ● CPU: Rockchip 3188 Cortex A9,1.6GHz,Quad-core CPU+Quad-core GPU
    ● Storage: 16GB
    ● RAM: 2GB DDR3
    ● Operation System: Android 4.2
    ● Camera: Front 2M, back 5M auto focus, flashlight
    ● WiFi: 802.11a/b/g/n (supports 2.4 & 5G WiFi)
    ● Internal 3G built-in: No
    ● External 3G support: Yes
    ● Bluetooth : Yes
    ● Sensor: G-sensor, Gyro sensor, light sensor
    ● Others: E-compass, Micro SD slot, mic, speaker, mini HDMI output
    ● Multimedia:Audio, Video(1080P), Photo,ebook,game, email, internet…
    ● Battery capacity: 4700mAh by 3.7V
    ● housing material: metal back
    ● Weight: 370g
    ● Size: 200*137*8.5 mm
    for more information please refer to Pipo Official website:www.pipomall.com
    Homepage
    Growth
    Learn
    Story
    Game
    I like the launcher.
    Is there anyway to port or extract this launcher? I have MK808.
      Re: New arrive PIPO U8 !!built-in the first Children Launcher of Android tablets
      +1
      Enviado desde mi GT-I9100 usando Tapatalk 2
        From my experience with other Pipo ROM's, the fancy UI stuff requires an activation code to use. I suspect they will implement some type of code to get this to work also.
        Randy
          Hopefully they'll supply the code along with the retail box this time, so you don't have to contact pipo with your serial number to get the activation code. I believe they introduced the activation some time after the M9 and M8pro was released, thus no in-box activation code.
          If they're sloppy - maybe they use the same algorythm for all activation. If so, your code for f.eks. M8pro or M9 could work on this launcher. But as codes aren't interchangable between same model tablets - I don't think you'll be able to port to a non-pipo device without cracking the activation. The activation codes are based on the serial number of the tablet - wich I believe is hardcoded into the tablet.
          Support your local flasher
          Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
            There's times I wouldn't mind a launcher for my kids. Like a catapult for example.
              LOL!
                That's good, at least we don't need to supervise kids playing time on tablet.The playing time can be controlled well by the system.
                But I don't think it possible to port or extract this launcher to other brand tablet, like you mentioned MK808. If you wanna try, you can ask their online service pipomall to request a activate code
                pipomall
                  You can also make a direct request to pipo: [email protected]
                  They're going to need a serial number to generate a licence key. Usually its on the back of the tablet and/or the warranty card.
                  Reports on SlateDroid say that a key for one tablet doesn't work on another tablet - indicating that the tablet serial number is coded into the tablet somehow. If you're to port this, you'll probably need to find a way around this.
                    AW: New arrive PIPO U8 !!built-in the first Children Launcher of Android tablets
                    We should not try to Port it when the Software got this restrictions.
                    This will be against the DMCA.
                    Neomode
                      Point taken.
