Beelink i68 reboots after Power-off
At this point, based off what you're seeing (which is very strange), I'd say go back to stock after doing the following procedure:- Use Android Tool 2.3> and select Erase Flash
- Flash stock firmware
 Once you get your power functions working again, make a note of the stock firmware that sets everything right and if you'd like we can begin testing to port those functions to a custom firmware. The reason I believe you should erase flash is because it seems there are remnants of previous flashes on your system and it's causing bugs to appear. That happens when multiple flashes occur, especially when partitions are flexed in size.
Originally posted by notShomari View PostAt this point, based off what you're seeing (which is very strange), I'd say go back to stock after doing the following procedure:- Use Android Tool 2.3> and select Erase Flash
Test Device Start
Test Device Success
Get Flashinfo start
Get Flashinfo success
Prepare IDB start
Prepare IDB success
Erase IDB start
Erase IDB success
Reset Device start
Reset Device success
Wait for Maskrom Start
Wait for Maskrom Fail
With FactoryTool i can flash stock firmware without any problems.
Now my beelink works correctly with this firmware: https://mega.nz/#!udZ0SJAJ!KxXsW5zC4...qL0FvzTjzURW5E
There are currently 1918 users online. 0 members and 1918 guests.
