Vido (Yuandao) N90 FHD RK3066 RileyROM 1.1 [Feedback]
    This is a custom ROM for the Vido N90 FHD RK3066. This is not for the 3188 version, there is another ROM for that.
    This ROM is rooted with 2, 4, 6 or 8gb of user app space, debloat with Google Play Store fix and init.d support.
    Download Link
    Thanks to Tattman65 for the wonderful boot graphics
    Thanks to Petrus for his Reboot app
    Thanks to the entire Freaktab team for support
    Enjoy!
    If this is the first time you are flashing one of our ROM's, you may encounter some challenges in installing Windows drivers. Please download this First Time User Guide to help you throught he process:
    Download
    In the ROM folder, there are 4 parameter files. The default is 2gb. If you wish to increase your user app space, just rename the parameter file to parameter2. Then, pick which size you want, and rename that parameter file to "parameter" before you launch the flash tool.
    Randy
