My current ZRAM value is set at 500MB with a swappiness of 60%
I can disable zram or change the swappiness of my ZRAM but I cant seem to change the disk size.
I tried this in the terminal with su
swapoff /dev/block/zram0
echo 1 > /sys/block/zram0/reset
busybox echo 157286400 > /sys/block/zram0/disksize <- I want to lower it from 500mb to 150mb
mkswap /dev/block/zram0
swapon /dev/block/zram0
I checked the value of /sys/block/zram0/disksize and its still set at 500mb or nothing has changed.
I tried to edit the manually but its not saving at all.
