YOKATV KB1 Amlogic S905X 2G/16G Android 6.0, 802.11AC WIFI LAN BT(2 HDMI In 1 HDMI Out)
    YOKATV KB1
    Operating System Android 6.0 Marshmallow
    CPU Amlogic S905X Cortex A53 Processor 1.5GHz
    RAM 2GB DDR3
    ROM 16GB EMMC
    Wifi 2.4G &5G WiFi Support IEEE 802.11 b/g/n/ac BCM4335
    Ethernet 10/100M
    Bluetooth V4.0
    HDMI Port Standard HDMI 2.0
    Other Interfaces 1* HDMI 2.0 output 4K*2K @ 60Hz
    2* HDMI 2.0 input 4K*2K @ 60Hz
    2* High speed USB 2.0,support U DISK and USB HDD
    1* TF CARD Support 1~32GB
    1* 3.5 Phone out CVBS&L/R output
    1* RJ45 LAN Ethernet 10M/100M
    1* OPTICAL
    Geekbuying
    As Found:
    YOKATV KB1 AMLOGIC S905X 2GB/16GB TV BOX FIRMWARE UPDATE 20161128
    Source: blog.geekbuying
      Hello Trebor, I have this exact same box but when I try to put the new img file via USB tool, the box just boots itself and never goes into picking the new image file. I am pressing the button in the A/V hole. Is there anything else I need to do to make it pick the new img file?
