Many thanks
Stock Firmware for T95N Mini MX+ TV Box Amlogic S905 Quad Core
Originally posted by Jethro View PostIf the MX+ and the M8Spro are the same, you can download the stock ROM from:
http://chinagadgetsreviews.com/downl...i-m8s-pro.html
Memobox / Memohi has a link for numerous firmwares including T95N MINI MX+ TF Card Update
Landing Page:
Firmware Downloads:
I tested the Mini MX+ and can confirm it works. I used the Amlogic USB burning tool
When attaching the box to the PC do Not use the external power, all that is needed is the power from the USB port.
Hello!
I buy this: Android tv box Amlogic S905X 2G RAM WiFi 4K Kodi 16.1 Loaded add-ons 1080i/p set top box Smart TV BOX
Brand Name:KEELEAD, Model Number:T95N
The wifi speed is slow, KODI, and same app often stopped. Available firmware for this box? (sorry for my english)
Thanks for the reply!
There are currently 4488 users online. 1 members and 4487 guests.
