K-R42 Kingnovel Android TV Box Rooted 4.2.2 Stock Firmware
I need a tester to check if it properly rooted becouse i dont have this box.
If i found this device popular i consider makeing a custom firmware for it.
If you like you can check out my website and press facebooke like buton.
You will find there some nice apps for your TV stick/box. http://apkfreak.com
This looks like a really cool device, what with the IR receiver and ethernet built in. Has anyone figured out what wireless chipset it has, and what hardware we have / don't have support for with the rk3188 source code that's out there?
I asked at geekbuying.com about whether source code is availabe, but I haven't gotten a response. Seems like a great device to use as a server, if we can get enough of it working.
the kernel of this device solve the video problem on t428.
wifi is different, but definitely the best result so far as regards the video problem.
can we have contact with the developer of this kernel ?
I would love that as well. I have only an mk908 to work with so t428 kernels do nothing for me. However I can build mk908 kernels so I´d love to know what the magic fix was.
If my work benefits you and you want to help out the cause, feel free to
Actually, this image works right out of the box on the mk908, just no wifi and I can´t get any usb net adapters working. Other than that, perfect video from what I was able to test.
Looks like a very promising device. Will love to see progress on this one. I was thinking to buy Imito QX1 as my upgrade from RK3066 but now I actually might try this one.
