Bricked M8 OTT
Bricked M8 OTT
My ott M8 it is hard bricked with red led on. when i short the 17-18 pin the led it goes to blue colour but my pc does not detect the device. i have install the drivers succesfully and i have try 3 (usb to usb) cables and nothing just happen. Please if anyone have the same M8 pcb or have any solution to unbricked it help me.Tags: None
try shorting 29 & 30 and make sure usb cable is on the outside usb portBugs are Sons of Glitches!
JustMe
can you take picture of the 2 usb ports teh actual board inside does it have 2 header pins if so you will need to short those 2 but first show me a pic
also what
1. operating system your pc running
2. usb 2 or usb 3?
have read over here : How to UnbrickBugs are Sons of Glitches!
JustMe
1. I have windows 10 x64
2. Usb 2
I have solder the two pins that is between hdmi and usb
The pics
Pins :
http://imageshack.com/a/img921/9366/NOcOyT.jpg
Board:
I have managed to unbricked my boxThe problem that my pc does't find the box is that: i have been connect the corner usb like every forum say and not the usb that is next to the hdmi. The otg usb for board M8 & M9 V1.1 Is the usb that is next to the hdmi and not that which is in the corner side of the box. After unbricked I have access to the recovery mode i have install several roms but no one can solve the wifi problem. I have to find a rom that my "M8" with S802 and wifi model AP6212 to be compabitle. I don't find any rom to fix my problem yet. There is any way to edit a rom to support the wifi AP6212?
There are currently 5056 users online. 0 members and 5056 guests.
