For this Giveaway we have a CHUWI HIBOOK PRO for you.
Thank´s to Chuwi for Sponsoring this GIVEAWAY !
Technical Specs:
Brand: CHUWI Type: Ultrabook OS: Android 5.1,Windows 10 CPU Brand: Intel CPU: Cherry Trail Z8300 GPU: Intel HD Graphic(Gen8) Core: 1.44GHz,Quad Core |
RAM: 4GB ROM: 64GB External Memory: TF card up to 64GB (not included) |
Support Network: WiFi WIFI: 802.11b/g/n wireless internet Bluetooth: Yes |
Screen type: Capacitive,IPS Screen size: 10.1 inch Screen resolution: 2560 x 1600 |
Camera type: Dual cameras (one front one back) Back camera: 5.0MP Front camera: 2.0MP |
TF card slot: Yes Type-C: Yes Micro USB Slot: Yes Micro HDMI: Yes 3.5mm Headphone Jack: Yes Docking Interface: Support |
Battery Capacity(mAh): 3.7V/8000mAh AC adapter: 100-240V 5V 3A G-sensor: Supported Skype: Supported Youtube: Supported Speaker: Supported MIC: Supported Google Play Store: Supported Notification LED: Supported |
Picture format: BMP,GIF,JPEG,JPG,PNG Music format: MP3,WAV,WMA Video format: 1080P,3GP,4K (4096 x 2160 px),MP4 MS Office format: Excel,PPT,Word E-book format: PDF,PowerPoint,TXT,Word |
Pre-installed Language: Windows OS is built-in Chinese and English, and other languages need to be downloaded by WiFi. Android OS supports multi-language |
Additional Features: Bluetooth,Browser,Calculator,Gravity Sensing System,HDMI,MP3,MP4,Wi-Fi |
Product size: 26.20 x 16.75 x 0.85 cm / 10.31 x 6.59 x 0.33 inches Package size: 36.50 x 22.00 x 5.40 cm / 14.37 x 8.66 x 2.13 inches Product weight: 0.550 kg Package weight: 1.200 kg |
It makes this tablet.
Keyboard is good to type on once you get use to the size of it and it has a metal top with two standard USB 2.0 ports.
CHUWI HIBOOK PRO Tablet the best you can get, good battery life, and keyboard dock makes it a good choice.
How can you Win this Device ?
Just leave a comment and tell us why you want this Table !
Rules:
The closing date is the 22.09.2016.
The winner will receive the CHUWI HIBOOK PRO.
What entry restrictions are there?
Only one entry per person.
How is the winner chosen?
The winner will be chosen by random.
When and how will the winner be informed?
The winners will be informed by email within 7 days of the closing date, and must respond within 7 days to claim their prize.
When will the prize be delivered?
The prize will be despatched, within ten working days of receiving the winner’s address details.
So have fun and leave your Comment below !
The Freaktab Team
If you want to Buy this Item you can get it here ---> http://www.gearbest.com/tablet-pcs/pp_361966.html
We have a Winner of this Giveaway !
It is Back to A with Post 326 !
Gratulation !
