MXQ Pro 4k Amlogic burning tool error 0x30402004
    I'm getting an error 0x30402004 with my player.
    Any idea on how to fix this?
    have you tried flashing your mxq pro 4k via the sd card slot?
      It doesn't work.
      Flashing via SD card works the same way right? I have to do the nand short method anyway
        I've the same problem My Tv box is briked now. Data is wiped no reovery mode is working. Please help Me
