what bothers me about nex box A5 and seeking your help
    hello every body i just got nexbox A5 and not very impressed
    i have 3 problems with this device and i was looking for your help
    1- when i install gmail it tell me thet it is synchronizing and stays for ever and doesn't work
    2- i need to unroot the device as i have apps that detect the root and doesn't work but super su says that there is no binary i think it is not rooted in the first place ! any idea ?
    3- there is no task killer or as they say the multitasking window which you can see the recently closed apps but still running and you can close any of them to save ram , can we get this ?
    4- copy and paste : i tried to copy a link and paste the URL but it doesn't paste at all , even the hyperlinks not working on the browser but hyper links works only on the chrome
    sorry for the multiple questions and thx in advance
    24 views and no reply !!
    help pls
      help pls
      It is all app updates or you can use different apps for your needs.
      No one can help further and the manufacturer already moved on the the next box.
        thx
          Try this firmware. I flashed it to my nexbox a5 and everything is good except you loose remote except it will power on. You will have root and navigation/notification bar.
          NexboxA95X+M8SII_Loth77MOD.zip
