Stream: video and sound asyncron
    Hello.
    I have a MK808 (with Finless 1.7 firmware) and it works fine.
    But when I want to watch a stream (App) or even youtube, I have a problem.
    The video and sound are asyncron.
    That means that the sound has normal speed,but the video is quite faster it seems like running double speed.
    The WLAN quality has 65 and it is just 40 cm close to the router.
    I already tried 3 firmware but always the same problem with the video stream.
    Anyone has the same problem or has a solution for my problem?
    THANK YOU VERY MUCH for your help!!
    No sorry but maybe
    hi,
    you use a proxy or something strange like this
    Tested a normal connect?
    Customkernel, overclocking or pimped like this.
    Sorry not morre ideas.
