ZRAM? How to edit disksize?
    I have a Kata Box 2 with s905 SoC with 1GB of ram
    My current ZRAM value is set at 500MB with a swappiness of 60%
    I can disable zram or change the swappiness of my ZRAM but I cant seem to change the disk size.
    I tried this in the terminal with su
    swapoff /dev/block/zram0
    echo 1 > /sys/block/zram0/reset
    busybox echo 157286400 > /sys/block/zram0/disksize <- I want to lower it from 500mb to 150mb
    mkswap /dev/block/zram0
    swapon /dev/block/zram0
    I checked the value of /sys/block/zram0/disksize and its still set at 500mb or nothing has changed.
    I tried to edit the manually but its not saving at all.
