I am getting a little better signal than before the mod, but I didn't see a huge difference. I was just curious to see if it would be any better. I may end up using those leads to connect more legit antennas in the future if need be. But for now I'm happy with it.
MK908 WiFi Antenna Mod
I just wanted to share my WiFi Antenna Mod for the MK908. For this mod I de-soldered the original antennas and replaced them with a pair of little antennas that came with my ASRock mini-itx motherboard. I followed Bob's video on foregoing the ground due to the solder shorting the antenna out, and used some blue nail polish to cover the ground braid on the cable. I also tacked down the cable leading out with some hot glue to keep it from moving around so much. You can check out my pics here http://www.freaktab.com/album.php?albumid=26
I am getting a little better signal than before the mod, but I didn't see a huge difference. I was just curious to see if it would be any better. I may end up using those leads to connect more legit antennas in the future if need be. But for now I'm happy with it.Tags: None
Too bad the T428 doesn't have solder points for a second antenna. That would help A LOT!TV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: Persus
There are currently 3933 users online. 2 members and 3931 guests.
